Loveless wrote:i hit it like 100 times and it won't go off, so I decide to PULL on the switch and still stuck
is there a way to trigger it? without using the swtich? maybe the switch is bad?
because my stupid hand had to hit the switch to pop it up during the day time and when I hit it again to retract, it won't go back down
Well, you can always supply power directly to the wire that is responsible for it going down. I had that problem with my pivot headlight controller when my controller was not connected properly since it spliced the "down signal" wire.
Behind the driver's side kick panel there is a black box behind the white TCU box. The black box is the headlight timer. You can take that out and check for burnt circuit board (probably not). I believe the wire that is responsible for making it go down is the pink/black wire. just use a multimeter and see if it gets 12 volts when you hit the "off headlight" button. If it is, then maybe a bad relay.
Another thing you can try is to manually turn headlights down w/ the turn thing-a-jiggy knob right next to it and see if they go up - if they don't, then bad headlight motor?
Hope this helps.
