Jdmstyles »
https://forums.nicoclub.com/jdmstyles-u119438.html
Wed Mar 18, 2009 6:53 pm
Unlike the emblamatical pop-up headlight button, mine is malfunctioning.
Anwyho here's the problem, and yes i've used that search button quite a bit but none really helped or was relatively similar.
I re-wired the brown wire as I found it cut when i bought it. But the problem is when i press it, it goes up and drops down instantly.
As for the headlight switch, the light comes on but the headlight itself wont pop up. However, when i press the headlight button it goes up and stays up. Furthermore, when i hit the high beam the light will go up then back down, unless i turn on the light switch then press the high beam.
I thought if I rewired the brown wire i can press it and have the light pop up but with the light off.
I'm not sure how to troubleshoot this as I'm new to eletrical stuff.
Any insights guys?
