Bruno240 »
https://forums.nicoclub.com/bruno240-u9783.html
Thu Apr 28, 2005 6:01 pm
what you do is.
!. pull out the headlight toggle switch that can turn your head lights up and down.
u cut the brown wire in there.
then you turn on your lights. turn them off and your headlights will stay up. then you tap the toggle switch untill your desired height. very easy
