s13 headlight
jdmciv
Car: 93 240 ka24de
s13 headlights will not flp up w switch r when turning on headlights & 1 motor gets hot and relay clicks....checked all fusses...what can I do???
x240xdrifter
Car: 1991 Nissan 240sx
english please? double check your fuses, if you ave spare relays around, replace the relays. if that doesn't help, print out a headlight wiring diagram from one of the FSM that can be found here. Trace the circuit and look for any cuts, rips or etc. that would cause your lights to short, etc.
JeromeS13
Car: 2008 Subaru Impreza STI
If the motors are getting more than a little warm, its probably the motors. If you check everything like suggested and everything is good, you probably just need new motors.
-Jerome
