cd1921 wrote:Im having some problems with my headlights. Only one of them is working.The driver side works fine, but the pass side, gets no power at all, and when i turn on the HI Beams, the driver side goes off.I went out and did an electric test. there is no power reaching the pass side, but when i switch to Hi Beams, i got a very dim light from the tester.
Does anyone know, what the problem is. I checked all the fuses, there all fine. Is there a relay or a light switch besides the one on the steering wheel column.Please help me, i need both light working.
LMK
You mean only 1 is working as in going up & down and not light wise right?
I think ppl were trying to help you from another post you had too .
Anyway, here's some more thoughts:
Since driver's side works fine, passenger side doesn't
relays for headlight controls are located around the intake box area, you'll see a box w/ like 8 relays in them.
Swap the driver's side relay w/ the passenger side relay
See if that fixes your problem (it should since it seems your motor is probably fine).
If it does, you can either go to junkyard and look for relays or go to me, i got an extra set (relays and motors) for cheap in socal .
