S13 Headlight Conversion
DriftingCrab
Car: 92 S13
Alright on the headlight i have the triple projection the outside bulb are driving lights, the middle are high beam but what is the last one and where does it exactly plug into its a 12v-60w bulb.
navysnail
im going to put this in 240sx tech. I think you will get a better response there.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
DriftingCrab wrote:Alright on the headlight i have the triple projection the outside bulb are driving lights, the middle are high beam but what is the last one and where does it exactly plug into its a 12v-60w bulb.
The foglamp is a H3C 2 prong bulb. Mine and I guess most others are ion yellow.
let5l1de
Car: 89 coupe w/ silvia aero, le mans sunset "do the 626 meet! DO IT!
positronone wrote:The foglamp is a H3C 2 prong bulb. Mine and I guess most others are ion yellow.
Yes. mine are yellow as well. triples.... I just completed my wiring for this using the cut connectors off the old popups, pulling a few unused relays, repinned the connectors for high and low beam action, and best of all it has the factory apperance... btw: i used a jdm fog lamp button (located in the dash bezel) from a 180sx for my fog or ambers and my combination turn signal/headlight for headlights... might i add... i impressed myself...
positron1
How did you wire those fogs up to that button?
