s13 head light problem... one light doesnt work...
hellboy006
im having this problem with my s13... the passenger side bulb doesnt work, i know its not the bulb itself because i switched them and had the same problem.... i also know that it IS NOT MY HEADLIGHT SWITCH... because i bought a new one and still have the same problem... someone said something about the fuses for the head lamps but i dont know where they are located... nothing in the fuse box says anything about the head lamps and the relays under the air cleaner box are only for the pop-up function as far as i know.... i also switched these and had no luck... i am thinking its a short somewhere... i just dont know where it would be.... under the dash or in the engine harness... what do you think? if someone can help i would really appreciate it... this is bumming me out hardcore btw the brights indicator doesnt work either if that helps.....
vancouverbc
Car: 1991 240sx
second post . hlamp fuse in relay box by battery
zerothread?id=140879
soulflyfn69
Car: 1990 240sx hatch
they are blue and say 15 on them in the fusebox near the battery at least on mine they are
hellboy006
thanks alot guys... ill check that out.
driftneil
Car: A pile of cars.
There is also a relay under the intake.
big_mike
Car: 1991 240 SX Coupe
I also had this problem and thought it was the fuse, but the fuse was fine. Turns out a bunch of water had collected in the large gray connector underneath the headlight housing. I unplugged it, dried it out, and it has worked fine since.
hellboy006
i just went out side, replaced the blown fuse and now my headlights are working fine..... what i want to know is why the fuse is blown.... i hope it doesnt blow again the next time i do any night driving......
big_mike wrote:I also had this problem and thought it was the fuse, but the fuse was fine. Turns out a bunch of water had collected in the large gray connector underneath the headlight housing. I unplugged it, dried it out, and it has worked fine since.
??? im not sure what connector you speak of....
driftneil wrote:There is also a relay under the intake..
i thought those were for the pop-up function only... but i may be wrong...
