ayjay »
https://forums.nicoclub.com/ayjay-u5495.html
Sat Feb 05, 2005 8:06 pm
just do this :P
ohhh right, weight is an issue... well if you still have all the carpet back there, i suggest just gettin a piece of mdf, cut it so it contours around the strut towers and wrap it in carpet, bolt that down and then you can solidly mount your amps and your basslink to it, will only add 20 lbs max if you use 5/8" mdf. just a suggestion, all you're lookin for is a place to mount everything. if you don't want to add the weight of the mdf, you can just mount your amps/basslink straight to the trunk, you'll be drillin holes in it anyways to make grounds.
