S13 hatch Fuel pump Question
menoura
I was reading a few posts about people hearing a priming sound of the fuel pump. All i hear is a small clump sound from the fuel pump. And thats for like a half of a second. I was wondering what the actual priming sound sounds like. Some people have said it pumps for 5 seconds, but I cant "hear" it. Or am I not suppose to hear it.
menoura
anybodys? :p
RideNslidE
Car: 1993 240 hatch the track and a 1993 240 vert DD
if it works why worry btw i cant hear mine
menoura
Well i have a problem thats why I posted lol. My engine wont crank and I have a feeling its the fuel pump.
Last time the engine ran it died a few times with the rpm goin up and down. I turned the key a few more times no luck. After a few turns it almost got it but no luck.
I checked the fuses relays even changed the spark plugs distributor etc etc.
The priming sound that everyone is talking about. I want to know if its very noticable, long, short sound. Anything will help.
Sileighty_85
Car: 1991 180SX
The fuel pump priming is very noticeable You will hear a huummm for about 2-4 seconds when the key is switched to the "ON" Position
Check for a 12V signal at the pump If you got 12V then pop off the Fuel Feed line for the injectors and click to the "ON" Postion and watch for fuel.
bretjohnson91
Car: 1991 240sx
also check your fuses and relays sometimes it can save you a lot of money. if not either of those have a friend turn the switch to on while you are in the trunk area and listen for a small humming sound.but remember it will only (humm) for about 2 seconds.
