s13 hatch doesnt want to crank up help-!!!!
JDMs13hatch
i already tired the fuel pump .. its good the ignition coil is good all fuses are good .. it does turn over but does not start it was crashed on the front bassenger side where the front head light is located .,. the frame was bent in a little .. please help!!
Nfire247
Car: 1990 240sx (s14 Ka-T)
check and see if its getting spark at the plug, if its not back up to the coil. If you are getting spark, make sure its getting gas (Pull a fuel line on the motor side of the filter, that'll tell you if you're getting gas up to that point at least.). Those are easy things to check for starters.
Once you narrow it down to spark or gas it'll be easier for people to help you diagnose the problem.
JDMs13hatch
i already checked if its getting gas and checked the coils.. some1 told me to check the injecters .. they may not be firing .. may it be that?
JDMs13hatch
