PercieBlaze »
https://forums.nicoclub.com/percieblaze-u229019.html
Fri Apr 18, 2014 8:31 am
Sooo.... this morning i decided to mess with the 40 as usual to try to get out its problems that keep popping up. i re adjusted the tps, found a vacuum line unhooked, reset the ecu, and that seemed too fix the high idle and rough acceleration. but then as im riding down the road my clutch goes to the floor and comes back up and my trans now has this weird noise coming from it. when you press the clutch in it gets worse. just moved in with my girl in some apartments so i gotta get some jack stands to pull the trans in the lot. im thinking its either the throw out bearing, the clutch, or somthin else in the transmission fork etc. FML
