S13 harness into a S14
jmhalder
Car: base model 95 S14, steeliez, boosted on the T25, going to HY-35, and 650's/N60/walbro/bikirom to han
has anyone ever sucessfully used a S13 KA harness in a S14 with a S14 KA? reason being, i think i'm gonna swap over to a S13 DOHC ECU, and although i'm already pretty much setup for it (U12 ECU with S13 connector spliced directly onto S14 harness) http://www.ka-t.org/forums/viewtopic.php?t=31358i just think it would be cleaner at this point to swap in a S13 DOHC harness, from what i can tell, all that would need to be spliced on would be my subie injector clips, the MAF plug, and the white connector for dash stuff (tach/coolant/oil presure/etc), i'd be getting the S13 DOHC main harness (to ECU) and sub harness (coolant/etc) will most of the other connectors be the same? its not worth it to me if i literally have to swap ALL the plugs over, lol.
