s13 going wrong
bytchezs13
Car: 1991 nissan 240sx s13
wats good peoples i got a fuking prob thats driving me up the wallllll , recently my s13 was sliping i figured it was the clutch , i did change the clutch and now i just ran the car for about 30 minutes and it ran fine no sliping all of asuden i started doing it again i was accelerating and i was going no were ??????? i was going like about 10 or 15 on fuking 3rd any 1 knows wats wrong with it
H8tred
A little more detail would help. What kind of clutch, did you do it yourself? Did you resurface the flywheel?
Roger_cha
Car: 91 nissan 240sx
well you said that you change clutch first what type of clutch did you buy and what brand, did you change the whole clutch as pressure plate, throwout bearing, pilot bearing and did you resurface you flywheel. if you did all that when you put the clutch in did you put it in the right way and tighten everything, if you did all that then when you put the transmission back did you put everything back the way it was, if you did all that too then it looks like you transmission is mess up. but double check on you work...
Razi
Car: Moo
Did you engage the clutch softly for the 300 mile break in period?Were you flooring it with the new clutch?
bytchezs13
i got a SE fast back and it was a stock clutch nothing fancy but like i said its like when i first start the car and take of its perfectly fine but when i ride it for about 30 min it starts to slip im going to post a video but if it was the trany what wld the side effects be?????
bytchezs13
http://www.youtube.com/watch?v=y3FbK79eDhs its some ting like this only when the car is warned up not when cold
Roger_cha
well i wouldnt say that its you transmission rite now but like i said if you did all of the things that i just said then i could be you transmission im not sure of it cause i know that for manual transmission you need a clutch to drive the transmission.
o and one more thing when you put the clutch back on is you hand greasy, cause if you put the clutch back on and have grease on the disk, pressure plate or flywheel then that might cause it to slip too..
bytchezs13
na no greasy hand did it all very clean let me ask u some ting wat about when ur lsd goes out
Roger_cha
well its very rarely for you lsd to go out the only way it will go out if you drive it with no oil in it other then that your lsd will be fine unless you or the previous owner drift with it alot.
Roger_cha
well you can check out this post if you might put the clutch in wrong.http://www.nicoclub.com/articles.php?id=168578
bytchezs13
koolkool tnx ma nikka
Roger_cha
no prob..
bytchezs13
hey do u noe is a95 se trany wld fit my 91 se
ZOMG.SR20
Car: 1990 s13
first grammar please second the transmission from a 95 will work but it has the speed sensor is on the bellhousing not on the trann itself iirc
Tsukiko
Car: 1990 240sx fastback KA24E
You sir, are guilty of massive grammar failure.
I hope you realize that most of us here on this forum detest having to decipher the gibberish you keep typing. After all...
Why answer your question when we have to make an effort to understand what you are trying to say? You get what you give.
bytchezs13
Tsukiko
notttt kool kid
Tsukiko
i dont sugar-coat it.
574-240sx
Car: Nissans, Toyotas, Subaru
Welcome to the life of a 240. Figure it out, it may take a while at times. I have had a trans in and out 4 times in the last month of a 5-speed swap car only to figure out Exedy sent me a wrong pressure plate.
bytchezs13
i found out the problem i didnt bleed the system right i just found another box like thing that the line went to and after bleeding that out work just fine tnx
Roger_cha
well there you go...
240sxFTW
Car: 89, 240sx coupe
Tsukiko did you paint you car at home or get it professionally done? Looks very good.
And yeah your grammer is in the toilet. No offense
AZ89two4Tsx
Tsukiko wrote:You sir, are guilty of massive grammar failure.
.....gibberish you keep typing. After all...
Jibberish starts with a j.
Tsukiko
Thanks!actually its a home job, OSH satin paint through a cheapie pneumatic gun.
and im sorry but i have never seen gibberish spelled with a "j".
gib⋅ber⋅ish   /ˈdʒɪbərɪʃ, ˈgɪb-/ Show Spelled Pronunciation [jib-er-ish, gib-] Show IPA Pronunciation–noun1. meaningless or unintelligible talk or writing.2. talk or writing containing many obscure, pretentious, or technical words.Origin:1545–55; appar. gibber + -ish 1 , on the model of language names so formedDictionary.com UnabridgedBased on the Random House Dictionary, © Random House, Inc. 2006.Cite This Source
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
sebazztard
Car: 1992 Nissan 240sx rb25det project. 2000 Honda Accord LX DD. 1992 Nissan 300zx NA.
not much to be proud of tho ^ lol
glad to see you got it sorted. most people keep coming on here looking for 60 answers to choose from instead of turning a damn wrench.
H8tred
I think he was thinking MR. T and gibber Jabber foo.
