S13 gauge cluster button removal
Guam180
Car: 1991 240SX SE
Okay I'm trying to swap a digital cluster into my S13 Hatch and I've seen the walk-throughs about it. However I'm stumped on how to remove all the individual buttons on the bezel.
I've managed to remove the hazard, rear defroster, and the cruise control buttons. But I'm having problems with the "manual headlight flip-up button", the dimmer switch and the plug for my Overdrive indicator light
(My car is a slushbox )
How do I get the rest off? Is there a trick to the rest?
Modified by Guam180 at 8:31 PM 6/30/2009
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
The way I was able to get my buttons off without busting the little tabs was to remove the cluster trim and push the tabs in from behind the trim itself. You can't pull it out very far unless you disconnect the buttons harnesessessesessesss...did I spell that right?
Guam180
Car: 1991 240SX SE
I did that. Seriously, I got the button popped out, and cannot remove the harnessessess from the button...
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
use a small tipped screw driver to depress the tab while you pull it out.
s13momentum
ull see a small little button or it looks loke ont on the harness connector push that in and it should com right off
moulton712
Car: coupe, hatch, both s13s
push the harness in, yes in, then press the tab and pull out
Guam180
Car: 1991 240SX SE
Edit: Nevermind I think I misread the past few posts....
Thanks anyways, guys. Some of those harness buttons just needed more encouragement with a pair of pliers...
