s13 fuel tank straps removal
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
I was wanting to know if the rear end has to be dropped in order to remove the fuel tanks straps completely. I have new ones to install and been searching around and haven't found a def anwser. thanks!
JayArr
Car: 1990 Nissan 240SX Coupe
Not if you're patient, the bolts that hold the straps are way up underneath, I think I needed to undo them with a wrench and they are lllonggg. Eventually they come off though and then there is a pin up near the bumper that releases that end of them. Put the new one into the slot and attach the pin then start putting the long bolt back in. It helps if you're a bit of a contortionist.
JayArr
Note, do them one at a time so the tank position doesn't shift.
NISSAN240SX12
1991 Toyota Supra
I started to remove the lllonggg @ss bolt and it jams right onto the rear end frame. I cant get passed it... :(
duffman1278
Car: 89 240sx Hatch, the wildcats!
FSM.....come on, stop being so lazy.
bigbadberry3
Depends how rusty your straps are :)
NISSAN240SX12
1991 Toyota Supra
The straps are rusted through completely and duffman i have the fsm and i have been through it so thanks for the smart @ss comments..... I wanted to know if there was another way other than dropping the rear end because i don't have all the time in the world I work 2 full time jobs and this is my only car. so that doesn't qualify me as being lazy so f*** off ***hole! Thank you everyone else for there input. have a great day peeps.
