S13 Fuel Pump wont prime
imGreek
Today, I had someone come over and we figured out why the KA24DE I put in wouldn't crank over. The problem was the grounds and now it cranks over. After that was fixed, we realized that we couldn't hear the fuel pump. It seems like it isn't priming.
What and how should I check the fuel pump? Could it be a relay?
Thanks
J14cm7
Car: 95 240sx S14 SR20det
There is a really good section on this in this thing called the FSM. Search around a bit and you will find a better answer to your question in that than anyone on this site can give you
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
Check your fuse first, make sure there is power to fuse. If the fuse is good check power at the fuel pump. If power is good there your pump is probably bad.
imGreek
J14cm7 wrote:There is a really good section on this in this thing called the FSM. Search around a bit and you will find a better answer to your question in that than anyone on this site can give you
Yeah, I've checked the FSM. I found the fuse; it's 10A on the passenger side.
Thanks for the help guys. I'll pull that fuse later and check it and test the voltage at the back.
