TurboCivicSedan »
https://forums.nicoclub.com/turbocivicsedan-u137085.html
Fri Jun 26, 2009 7:01 pm
I got a friend with a '93 S13 SE...his problem is that when he turns the key to the "on" position, his fuel pump doesn't turn on, now if he turns the key(as if to start the car) without pressing the clutch in, the fuel pump turns on (fuel pump can be heard turning on at this point) but obviously won't start because he doesn't have the clutch pushed in to enable the motor to start. he's pinned it down to being an electrical issue. he's changed relays, checked fuses, swapped out his ignition switch and nothing. What can be wrong here? thanks in advance!
