S13 Front conversion hub issue
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Last week I pulled my front hubs and the rest of the suspension components. While it was all apart I decided to replace the inner and outer tie rods, and control arms. So today I decide to test fit everything and I have an issue.
I purchased some 5 lug conversion hubs about 2 years ago from Ichiba and just now started my brakes and conversion.
But the hub slides onto the spindle fine but when I tighten the hub bolt it doesn't make contact with the hub. The old hubs had 2 notches that they clicked into where these do not. I am confused, am I missing a spacer of sorts?
I don't see anything on here, and here is a pic of what i have going on. Behind the nut in this pic what is that? A wash a spacer? is it grooved like the spindle Please help
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
I just found this pic here
Notice the notch on the old hubs, Did I need to pull that thing out?
I also tried calling Ichiba but no answer, worst case scenario I cam trying to recal from bad memory did the S14 fronts bolt right onto the S13. If so I can probably buy a set from autozone or something.
sultan
you need these things? http://www.superstreetonline.c....html
could be stuck to your old hubs i guess
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Oh thank god I thought I got the wrong hubs by chance. Ill call the dealer and get them on order. Thanks a million man
Part number is 40264F6600 incase someone needs it.
Modified by OutToWinPAHC at 7:30 PM 10/3/2008
94_240sx
Car: 94_240SX
sultan wrote:you need these things? http://www.superstreetonline.c....html
That's cool, sultan.
/threadjackI went through all the pictures and they didn't bench bleed master cylinder. Is that okay?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Did not work for me.... After stripping two I took the one to the machine shop and had them remove it.
I am doing the same swap, but using Z33 track rotors and those brackets you see.
94_240sx
Car: 94_240SX
Mine came out easily somehow. I also bought 17/16 MC that has 3rd fitting already pressed in. I'm about to do the very same swap, but on 4-lug. Yeah, I noticed R1 Wurks brackets on yours. I have JSK's.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
I see the same helicoils in you adapters. In stead of using the OE caliper bolts I purchased a set that was 15MM longer and put a lock nut behind the bracket. I just don't know if I want to trust 500HP stopping hard on helicoils pressed into aluminum. I would do the same thing. Cost me like 6 extra bucks but I know its secure and I like that piece of mind.
But yeah my MC's looked like they were factory locktited I tried PB blaster and no luck so 25 bucks at the machine shop did it right.
94_240sx
Car: 94_240SX
This could have worked. Anyway, thanks for the tip.
