eh... not really. They have bolt on spacers for 15mm and thicker that you can just screw on to your existing studs.gumby74 wrote:ANNNNND if you plan on running spacers, you may want to look into longer wheel studs, on account of that whole wheel coming off because the lug nuts only went on with 2 turns thing.
jrb240 wrote:to yokota, thanks d!ck, and i seriously do appreciate the other replies
not true, i just talked to a buddy who has these wheels in 8" and he has a plus 25mm on the rear and plus 35mm on the front and they are perfect, so i guess i need a 10mm spacer...thanks for the help alladrians_s13 wrote:eh... not really. They have bolt on spacers for 15mm and thicker that you can just screw on to your existing studs.
in his case, 8" +35, he'll need like 25mm spacers to make the offset a +10, which I think is flush
well, I guess our definitions of perfect differ...jrb240 wrote:not true, i just talked to a buddy who has these wheels in 8" and he has a plus 25mm on the rear and plus 35mm on the front and they are perfect
makes me wish i had my wheels on...*sigh*adrians_s13 wrote:well, I guess our definitions of perfect differ...
here's my definition...
your definition is about 15mm in more
