I just updated my build thread (there's a link in one of the above posts if you're interested) and wanted to update this thread as well. I did a very rudimentary alignment myself and can drive the car around town without too much of an issue.
I lifted the front of the car up a bit higher than it was before I did the above mentioned suspension mods. I did this to get closer to a stock roll center. This created an issue with the tie rods, though.
The old PSM knuckles that I installed have the tie rod mount lower than stock to "correct" the angle of the tie rod when very low. It would seem to me that you would always want the flca and tie rod to be parallel to eliminate bump steer. Maybe there's an issue with the functionality of the tie rod when it is at that extreme angle on a lowered car that dropping the mounting point alleviates. I'm not sure (I haven't run the car with these mods low enough to find out), but obviously it's better to correct the roll center and leave the height of the tie rod mounting point close to stock with respect to the ball mounting point so the tie rod and flca stay parallel to each other. This is what I intend to do eventually (with PSMs new super angle roll center corrected forged knuckles), but for now it's angle over no bump steer.
The car actually handles pretty well (I really haven't driven it a whole lot, though). I would say better than before these mods. I attribute that to the fact that my roll center is closer to stock, the sway bar bushes are new and urethane and that I have Tien coil overs instead of the cheap and broken coil overs that were on the care previously (too bad S13 rear coil overs don't fit S14s). The car does have really bad bump steer, though. As stated above the original PSM knuckles were designed for cars that are lower than mine. When the flcas are at that roll center fubaring angle dropping the tie rods down puts them almost parallel to the ground. This means that when you go over a bump the flca and tie rod are both past the apex of their arcs and are moving in the same direction (flca and tie rod mounting points on the knuckles are both moving toward the inside of the car). The flca being further along in its arc moves in further for every unit of suspension travel, so you will still have some bump steer no matter what with these knuckles, but I would imagine it's not too bad when you're really low.
My issue is that when I raised the car up it puts the tie rod past the apex of its arc so that when the suspension compresses the tie rod mounting point is moving toward the outside of the car. I did not raise the car high enough to bring the flca past the apex of its arc so the flca mounting point moves toward the inside of the car upon suspension compression. This causes the knuckle to turn in when going over a bump creating really bad bump steer. If I hit a bump with both tires simultaneously it's not so bad as both wheels turn in at the same time, but otherwise it's pretty bad.
I am getting some other issues with the car buttoned down. Once I do that I plan to take it to Sonoma Raceway (formerly Infineon) to see what I can do with these knuckles, a serious clutch and solid mounts.
