s13 engine swap help please
s13fred
Car: 1994 200sx s13
:dblthumb: hi to you all ive just brought my first s13 last week its a 1994 model been converted from auto to manaul when i brought it i was told the turbo was blown as it was giving a lot of blue smoke when under boost so i invested in a new turbo and guess what ? you got it it STILL smokes :frown: also it runs lumpy when warm and it revs high when warm when i turn it off and wait for the 30seconed turbo timer to go down it cuts out befor the timer has finshed due to running awfull when warm any the plan is to hopefully use it while i get the bits to convert it as i want to put a sr20det in the place of the ca18det how easy is the swap what parts do i need is the any sites that show step by step of the conversion ive been told all i need is engine ,box,engine loom ,do my engine mounts and gear box mounts fit as for the engine loom will it just plug in mine sorry for boring you any help would be great thanks fred :bigthumb:
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
EVERY possible thing you could imagine needing is on this page or linked from this page:
rwd-sr-faq-version-2-0-t306956.html
/thread
usar89b
Car: 89 Nissan 240sx
Sounds like you need to get busy real soon on another engine. Also, check your brake booster to make sure the master cylinder isn't leaking into the booster. If brake fluid gets into your booster, then it will be pulled through the vacuum line into the intake. This will cause blue smoke in the exhaust just like you were burning oil. But I think you are just burning oil. How often do you have to fill it with oil?
btm88
Car: 1993 S13 Convertible
Ca18det's are pretty old motors, and most likely you are getting lots of blowby. Just my opinion.
s13fred
Car: 1994 200sx s13
top stuff for that link speedeast :dblthumb:
2 days ago i gave the car a oil change as when i checked the dip stick some dozy pr*t had filled it up double with oil ? like this when i got it
any way drained the oil out and it was very runny but no smell of fuel good sign
but it was blowing oil out of the dip stick befor i drained it due to over filling it just checked the old turbo and there is loads of play in the shaft and also YOUR LIKE THIS the previos owner had put a t28 turbo on it BUT for some reason it had been WELDED to the manifold so it could be the turbo what caused it to smoke as when it was welded it could of melted the rubbers in the turbo and the smoke left could be whats sat in the exhaust just burning off? i hope anyway :confused: some one has told me to clean the idle control valve ? where is this what does it look like and how do i clean it sorry for being so dum but i have had no dealings with jap cars before
speedeast
Rubber in the turbo?
Sugar
Car: S13 w/ Sr
The turbo wouldn't have gotten hotter when welding than it does when the car is running. If you ever temp gun your turbo that will get over 700 degrees F' at idle.
Sounds like you may have multiple issues though. Check compression, then start replacing things. if you have a lot of shaft play then the turbo would be a good place to start.
speedeast
I think everybody misses the point.
He wants to know how to swap to an SR20, his engine of preference.
Sugar
Car: S13 w/ Sr
Oh yeah haha whoops.
Swap is cake. Stock mounts, KA or SR im not familure with the CA18 but I would assume it uses the same as well. The wiring is very simple. Everything is so well documented online that any issues you are having are easy to find.
thoughtless
Car: 1997 silvermoss 240sx SE
...esp since youve got the S13
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
it shares the same mounts. theyre all the same car. just make sure all the pins for the dash plug mate up the same i.e. tach to tach, speed to speed ect. if u want another ca for simplicity tho i have a spare motor. fresh rebuild, no turbo tho. the 2860 went on my current ca :chuckle: also if its a ca in the car youll need to wire up consult as ca does not support consult and sr does. idk why u wouldnt want the ca tho, i love mine. even when it was stock with a red top sr t25 on it i made 248whp, 227wtq on 10psi with just the usual i.e. fmic, turbo back exhaust, safc to calibrate in my n60 maf and that was it. not too shabby for a little 1.8l in stock form
s13drifter88
to me it sounds like u just need to re-do the head. get an oem ca18det head gasket set and arp studs (need to be replaced after use so get good ones lol). itll be cheaper than an sr and itll make excellent power. i just dont care for the sr to much coz ive seen what happens when rockers jump off the lifter and stoppers arent advised for stock lifters coz they can actually damage the lifter over time. maybe they work for some people but 2 separate times ive seen a nightmare. plus if u drift, at high rpm the waterpump likes to start to cavitate and could result in overheating. an underdrive pulley can stop that but just like my friend who had the 2 head nightmares now overheats when stopped from the underdrive pulley
s13fred
Car: 1994 200sx s13
thanks guys really top stuff
thanks for the offer of the ca but ill go for the sr swap cheers again :dblthumb:
