homeslicej2 »
https://forums.nicoclub.com/homeslicej2-u54419.html
Wed Apr 18, 2007 2:09 pm
So I see you have already upped the boost (something I suggested in your other thread). The T25 is a little turbo, maybe it's pumping too much heat with the higher boost levels (due to age it may have lost some efficiency too, but it's not efficient past about 13-15 PSI max). How are your plugs? Is your timing correct? Coilpacks going out maybe? Coolant temp sensor bad? I'd check things like that out.
