NateDogg »
https://forums.nicoclub.com/natedogg-u710.html
Thu Sep 23, 2004 6:14 pm
Well, good news and bad news.
Good news: I found out the problem. Walbro 190 killed my fpr. For two years it ran fine and passed emissions but now the base pressure is up to 40psi with vacuum connected and 50psi without. So that is about 6-7 psi too high. I would assume the 255lph pumps do more damage.
Bad news: I gotta pull out the Walbro and put in a stock one. I can't afford the Nismo regulator, yet. EDIT: I'm having second thoughts that a busted fpr might not even work with a stock pump..I will know tomorrow I guess. Anyone have any experience about this?
Thanks for the help, everyone, especially s13sr20chris. I am so glad I can finally FIX the problem. After going through my entire engine, I now know I won't have to look at that mess again.
This problem should make people aware that any aftermarket pump may cause a poor idle, power loss, increased emissions and higher fuel consumption.
Hope somebody else can learn from my stupidity.
Modified by NateDogg at 10:29 PM 9/23/2004
