Phax »
https://forums.nicoclub.com/phax-u2813.html
Mon Jun 02, 2003 1:56 pm
About half a dozen times over the last couple of months, I have gone to start the car and it refuses to start. The electrical system starts to come alive, but as soon as I click it over to start, all the power drains. Even the clock goes out. Returning the key to the off position and attempting to restart does not bring the car back to life.
Through half assed diagnostic techniques, I think it's some where in the ignition system. Removing the 30A ignition fuse and wiggling the battery cables seems to "fix" everything. Yet the situation continues to occur, so I'm in search of a more permanent solution to it.
Have any of you ran into similar symptoms? What's the best way to track down an electrical starting problem?
There are two "strange" electrical symptoms that I have noticed. One is that the clock resets itself to 1:00 every time I turn the car off. The second is that after turning the car off, the automatic shoulder belts will not go forward when the door is opened. Is that normal for Nissans? My 87 Starion had nearly identical automatic belts, and they would go forward even after the key had been removed from the ignition.
