Dano »
https://forums.nicoclub.com/dano-u2493.html
Tue Feb 13, 2007 10:47 am
First off, Welcome to NICO!
As for your hatch issue, check our classifieds forum! It's the most active Nissan/Infiniti classifieds on the web!
In regards to your electrical, I would first check out the engine fuse boxes and check to make sure not only the fuses are fine, but more importantly the larger, fusible links. From there, if your having almost all electronics failing, you may want to opt to pull the wiring harness out of a junkyard s13 or find one from someone parting an s13 out and just toss your old one. Good luck with these issues!
-Dan
