s13 driveshaft/transmission/differential promblem?
s3teen
Car: 89 s13 240sx, 93 s13 vert
Just complete my 5lug swap. I put it in gear and disengage the clutch and car goes no where. It sounds like my shaft teeth that spin the wheel are just stripping. . When I put in 1st gear, it just rolls. could it be the diff?
94_240sx
Car: 94_240SX
Jack up the rear wheels, turn them and see what happens.
s3teen
yep car is in gear, right rear tire just spins. the axel (shaft) doesn't move. I f***ed up bad. I already know
s3teen
well come to find out that my rear hub's are the turbo ones so the splines (teeth) are different.
s3teen
yay for me, more money out of my pocket..CAn't trust people. F**KIng ricer's...stick with your hondas ** wipes.
Modified by s3teen at 12:47 PM 5/20/2009
s3teen
so does anybody know where to find some oem non turbo rear 300zx hubs? Greatly aprriciated
Only ones I can find...what do you think?
http://cgi.ebay.com/NISSAN-300...l1177
Modified by s3teen at 1:15 PM 5/20/2009
94_240sx
Car: 94_240SX
Don't do it. Shipping will kill you.
s3teen
So I am just gonna get 5 lug hubs and go back to stock calipers in the rear. This route will cost around $300 as to buying $800 brand new hubs/bearings that are non-turbo. So LESSON LEARNED!!! DONT BUY REAR 300ZX TT HUBS. NOOOOB BOOOBY
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
you should have known the item before hand. did you ask the seller first if its for an NA?why did you swap the whole rear end? if all you need were hubs, knuckle, and spindle.
s3teen
So In order for me to do 5lug for the rears, All I need is stock calilpers, redrill rotors and ichiba hubs right? just checking in so I don't miss nothing.
94_240sx
Car: 94_240SX
s3teen wrote:So In order for me to do 5lug for the rears, All I need is stock calilpers, redrill rotors and ichiba hubs right? just checking in so I don't miss nothing.
Don't use Ichiba hubs for the rear. Get z32 NA hub. OEM quality is better than Ichiba.
