DriftingisLame »
https://forums.nicoclub.com/driftingislame-u25409.html
Thu Oct 06, 2005 11:49 am
I'm installing the driveshaft on my rb20 swap and it seems to be like 1/2 inch too long. The front of the driveshaft right before the part that goes into the transmission (output shaft?) seems to be resting firmly on the little metal ring that seems to be covering around the hole for the output shaft... It seems as though that is its only purpose, can I cut this off? I'm 95% sure it will fit if I cut it off, but I also do not understand why I would have to, I've never hear of this not being a direct fit.
Any help is appreciated, I'm veryveryveryvery close.
-Max
