s13 double projectors
redline454
Car: 93 240sx Coupe
2002 Pathfinder SE
2007 Subaru WRX STI
2004 Subaru WRX
1998 Subaru OBS (RALLY)
hey i have the double projectors setup on my 240 and i swapped all the bulbs out for brand new ones... but the driver side is still really dim..i know they are for RHD but they seem a little too dim.. idk if its my ground or something
any1 else have this prob?
Rucca
Test the resistance in the wiring. Sounds like high resistance in wiring from either corrosion, bad connections, or loose grounds. If you can, measure the voltage and amperage at the bulb connector and compare it to the other side.
redline454
Car: 93 240sx Coupe
2002 Pathfinder SE
2007 Subaru WRX STI
2004 Subaru WRX
thanks ill try it
