altho im listing only the parts that i think will get this thing running, my goal is 350dd/road coarse hp, WITHOUT HAVING TO BE REDUNDANT with the whole upgrading parts i already bought to support that need, anyway, let me know if im missing anything that will make turning that key a nightmare, or if you have any part suggestions
i noticed my clutch was wack so first off,
NISMO SLAVE CLYLINDER
NISMO SS CLUTCH LINE- any alternatives?
REDTOP MOTOR/TRANS/ECU/UNCUT HARNESS SET- 175psi i hope? prolly lucky to get a 155
IGNITER- 95 q45?
SPARK PLUGS- BKR6EIX heat range 6 for now rite?
OEM OIL PUMP KIT- any seals that i need to order also?
OEM WATER PUMP-
STANCE WP PULLEY- i like to revmatch, am i getting ahead of myself? should i ditch this and get a new thermostat instead?
GRIFFIN RADIATOR- custom mounts, any1 running a griffin? i see all koyos
SILICON RADIATOR HOSES-
HEATER HOSES-
BELT SET-
AVID RACING MM/TRANS MOUNTS- could i hold off on these?
GREDDY OIL PAN/FILTER RELOCATION KIT-
APEXI GT SPEC DP-
APEXI NOIR EXHAUST-anyone runnin this? is it actually quiet?
ISIS INTERCOOLER WITH ALL PIPING- i chose this cuz its cheap, but will i end up buying 2 intercoolers when i reach my hp goal?
BATT RELO KIT-
TIAL ALPHA Q(nice name) BOV(bong)- will i have fitment issues with this? i will need to use a weak spring for low boost right?
JWT Z33 CLUTCH/FLYWHEEL COMBO- anyone else but codyace do this? does it really work?(codyace-do i use the JWT pressure plate? or source an sr pplate)
zeropost?cmd=newtopic&id=17#
ARP FLYWHEEL BOLTS
is there anything i could cut from that list to make this happen sooner? or will it contradict my do it once do it right mentalitykeep in mind i know this setup wont get me 350, i just want to be on the right track to that...
