s13 dohc distributor question
Jayson240
I need to replace my crank angle sensor (code 11) and finally found out it was integrated into the distributor. I was wondering what the 'module' on the distributor is. Most of the parts shops sell a reman distributor w/o module. Please help clarify.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
On the DOHC KA ive heard that the ecu also throws that code for the TPS sensor... Not 100% sure if that is correct but you could try looking around a little bit. I know the sohc has that sensor in it and you can change it but i dont believe the DOHC has it... If you need a DOHC Distributor let me know i have two in working condition here ready to ship. Email me if you want [email protected]
GL
tunerinms
Car: '93 s13 coupe
Crank Angle or Crank Position? If its crank position the sensor is on the back of the block on the exhaust side. And it just comes out and gets plugged back in.
