S13 distributor
Slide615drifter
Car: 240sx ka- t
At TDC is an s13 distributor rotor button perfectly horizontal and an s14 slightly up from horizontal?
lexcrob
Car: I get a different ride faster than I could update this.
Nope they point in the same place its really the exact same engine. ka24de is same as all the others. a ka24e would be a different animal.
I know that to put it a tdc it does not point at number 1 but a bit after it. I will probly be corrected on this but the spark takes place before the piston reaches tdc. So when you put a distributor at tdc. The pointer is like the next tooth past number 1.
lexcrob
I always just google (ka24de tdc) click images.
WDRacing
