s13 digital climate question?
slow s13
Car: cars, photo, music
For those of you that have done this when did you get the actuall display to light up? The one I have has the complete sub harness and when I hook the 2 main plugs and the power wire into the car it doesnt do anything except when I turn the lights on the backlights for the buttons come on but no display. All the sensors except the one that goes by the radiator are hooked up but as far as I know it should work anyway as they only effect the auto setting. This is on a 92 coupe. Im kinda thinking it may be broken as most say this is mostly plug and play with just a few mods to make the fan work which I have not done yet because I want to see it work first.
94_240sx
Car: 94_240SX
That thing gets fried easily. I have a feeling that yours is bad. Display unit alone is not that expensive, so I recommend you getting another one off eBay or something.
kouki munster
Car: 97 base 240
You can not just plug the unit in and have it work, you also have to supply a power and ground to the unit for it to work, search and you will find it.
