slimcat7m3 »
https://forums.nicoclub.com/slimcat7m3-u39282.html
Mon Apr 23, 2007 4:33 am
Hey man I just pulled two diffs apart last week and both were the same. If you are looking into the diff with the cover pulled off; starting on the left side it was big shim, little shim, bearing, diff, bearing, small shim. Make sure you are looking into the diff w/ top side up. Thats how both of these were but make sure to use common sense when putting it together. If it doesn't seem right it probably isn't. FSM for proper measurments like codyace said.
