s13 cruise control not working
rod0921
Car: S13
got a 91 240sx le...tried using cruise control, light comes on but doesnt actually work...any ideas? thanks.
s13sr20chris
ascd control module is common but the light does not usually come on in that case. check the relays and the cable to make sure its hooked up.
topdowninaz
Car: 1994 Nissan 240sx SE
My light doesnt come on at all for my cruise. Is there a fuse somewhere I need to replace?
topdowninaz
The cruise itself doesnt work either.
94 - 240
topdowninaz
While I am at it, my horn doesnt work either.
s13sr20chris
if the light does not come on then you prob have a blown fuse. i would check that first.
s13sr20chris
for the horn, check that you have power at the terminal on the horn itself while someone presses the horn pad.
topdowninaz
******Warning Dumb Question******
Where is the fuse for the cruise control. All the fuses in the fuse box by the driver side leg are good.
s13sr20chris
fuse for ascd is in the fuse and relay box under the hood. its the 10amp fuse at the bottom of the box. its in the middle of a 3 fuse row. there is also a fusible link at the top that supplies it too.
