GroundZero »
https://forums.nicoclub.com/groundzero-u9436.html
Thu Aug 21, 2003 3:30 pm
yes the coupe is lighter and more rigid, but there is a limit to how rigid a car can be. aerodynamics is another story either a car has it or it doesn't, aerodynamic improvements can be made to the coupe but thats money that didn't need to be spent or could have been spent improving the already superior aerodynamics of the FB.
The same rigidity level can be reached in either car with strut tower bars, sway bars, ladder bars, maybe some subframe connectors, roll cage, control arms, tension rods, springs, shocks, pillow ball mounts... the list goes on. seeing as you'll be putting most of these parts on which ever one you get it doesn't really effect the differance in weight. if you really want you weld a couple bars in behind the back seat of the FB.
The weight issue of the FB is nothing to be concerned about, weight is easily dropped by stripping out the interior, stripping the car down, changing out metal body parts for fiber glass or carbon fiber, switching out the glass for lexan, removing unessential components such as the ac system or audio system. me and my friend dropped about 50 pounds off his mr2 by removing unused bolts, brackets, and other useless hardware.
my overall pick would be a 1991 240sx Fastback SE like the one i have, i have the super hicas model which you might not want because of the extra weight. but ultimately the choice is up to you, just throwing my opinion out there like you wanted. good luck picking and building your car.
