s13 coupe stitch welding
rps13srsc
Car: 96 240SX Base Model
i need to find out any info i can on stich welding my car its already tore down for other work and i would like to stiffin it up while im at it any info would be great
rps13srsc
bump
180fan
Car: 89 fastback
well what exactly are you looking to find out?
rps13srsc
as much info as possible i want to do this myself
sr20goofus
get a mig welder...anywhere you stitch two seams togather be sure to expose bare metal first with a wire wheel or sand paper. once everythign is cooled down, repaint
a_ahmed
Car: 1991 240sx fastback
im interested in my non-coupe s13... i want to stich weld myself as well... whats required and where would one stich... etc... plz more info cmon
180fan
Car: 89 fastback
from what it sounds like you're green on welding. I'd suggest taking it to someone who's got experience with it instead of doing it yourself.
From calling a fastback a "non-coupe" and where you'd stitch, what's required and all those details come from experience. Reading stuff online don't make you good with welding either. Get it done by a pro.
sr20goofus
to prevent fu*king up teh metal, have a good shop do all teh stitch welding, but strip your interior completely to prep the job for them and save yourself as much moey as possible,. If they do just teh stitch welding, you will save a bundle.
Malac0da13
Car: 1992 Nissan 240SX Convertible
i thought the stitch welding was done with one of those "c" clamp looking welders that like spot weld i may b wrong tho...but yeah i would go to a pro...otherwise youd prolly just waste your time for nothing
LayNLow240
Car: 92 240 coupe
Malac0da13 wrote:i thought the stitch welding was done with one of those "c" clamp looking welders that like spot weld i may b wrong tho...but yeah i would go to a pro...otherwise youd prolly just waste your time for nothing
your thinking of a spot welding machine.a mig and tig can weld for what you need. spot, stitch, continous they can do them all.only thing im going to say is weld like your putting your wheels on. weld one inch secion on left strut tower, then an inch on right strut tower, then left and right etc. as far away from each other as possible to keep the heat down. just space them about an inch apart.
