s13 coupe not starting
6footmidget
Car: s13 coupe
quick info:s13 coupe with a 97 ka
my 240 isnt starting, a week ago i unplugged my alarm and it started and drove around fine, and now it wont start at all
its not the battery cause theres power and the fuel pump is priming but when i turn the key past two clicks to start it nothing fires up at all
vmiramon69
Car: 1993 s13
u need more details bro...but isnt ur alarm connected to the starter???idk i would start there
6footmidget
Car: s13 coupe
well when i took out my alarm it still started, i just left the car alone for about a week and now it wont fire up, im still trying to figure out which plugs go where
teamelude
Car: 1993 240sx Nissan
Did you check your clutch switch maybe the button might not be depressing thats happen to me and I was late for class because of it.
6footmidget
Car: s13 coupe
hmm.. at first i thought it had to do something with the clutch too, care to explain where that thing is youre talking about?
Klits562
Car: white s13 coupe
it should be a little switch behind the pedal i believe on the floor? Idk i've never done anything with a manual but i know of the switch.Is the starter clicking?If it is clicking is it once or multiple times?Is the motor turning over?If its turning over is it slow or fast?Or do you turn the key and literally nothing happens?
6footmidget
Car: s13 coupe
i turn the key and literally nothing happens
Klits562
My friend removed his alarm a week ago car didnt start so he reconnected the wires that he cut off the alarm to the wires that went out of the alarm(i think) and the car started up.
Do you have any loose wires? If so try reconnecting them. The wires are all color cordinated so it shouldnt be to hard.Why did you remove the alarm? If nothing else works if you still have it sitting around you could always reconnect it and see where that takes you.
Also did you check to see if the switch under the clutch was stuck?
Also the clutch switch is at the top of the pedal http://www.garage411.com/image...1.gifpicture of it
6footmidget
Car: s13 coupe
ill do it this weekend and post up my results
and i removed my alarm cause it wasnt working
Klits562
good luck n let us know
6footmidget
Car: s13 coupe
okay it started!! theres like a hole? or something missing from the button so im just gonna glue something onto it so when i press my clutch itll press the button thanks guys!
teamelude
Rubber part that hits button
6footmidget
Car: s13 coupe
its hard to see what the second picture is but i know what youre talking about, i found that big round thing on the floor somewhere
teamelude
Than thats what is making the car not start it is on the clutch pedal assembly without it when you press the clutch pedal it will go through the hole on the clutch pedal assembly so if that was on the floor and you found it you just put it back in on the clutch pedal and it should start sorry for the blurry pictures my phone is not the best at taking them. Tell me if it works
