S13 coupe Loose front struts?
HIcoupe
Car: 1992 S13 Coupe SE
I recently bought my old s13 coupe back and i just noticed a problem on it, it has cusco coilovers all around but what is that mean if im pressing on the brakes and both sides of the front wheels come to a stop but if feels like it leaps forward like its loose and when you let go of the brakes its stable with the ground?
Klits562
Car: white s13 coupe
Your description is kind of confusing but lemee see if i cant figure it out.
So what your saying is when you hit the brakes the car nose dives? well if so then i'd say your coilovers are pretty worn out and its time to replace them, or have them rebuilt
HIcoupe
Ok I hope that's the problem, but yeah when I break it feels like the front axles are loose? Not sure I'll look more into thanks
poshatch
Car: p.o.s. 1990 240sx hatch
mine did / does the exact same thing
first check the collard to see if they are locking where they mount to the knuckle
then if that isnt it then it was also my tension rods were lose and it would cause it to clunk when breaking
so annoying but yeah its probably either of those two things, then if it isnt that then check the strut tower and then lower control arms lol
basically everything down there should be snug haha
xnyc1
you dont have front axles. maybe your control arms. check the bushings and your lower ball joint
poshatch
xnyc1 wrote:you dont have front axles. maybe your control arms. check the bushings and your lower ball joint
fyi i believe you check this by jacking up the wheel and trying to tilt it side to side and and up and down, usually side to side is tie rod wear and up and down is ball joint wear
in either case this should help you locate some form of play
