S13 Coupe "Clunking Sound in the front suspension"
hapaboi39
Car: 93 NISSAN 240SX COUPE
Whats up fellas!
I have a 93 s13 Coupe and i have this crazy noise coming from the front whenever im traveling at low speeds. For instance when Im backing out of my driveway it makes a sound like "da-dunk" and it feels like something is popping out. Or when Im driving in a parking lot and I turn into a space I hear the "da-dunk" coming from the front suspension. When I travel at higher speeds the car kind of shakes.
Sorry I dont have a better description of the problem but hopefully one of you guys will know what im talking about.
Any suggestions would be helpful.
Thanks
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
I am assuming you pulled off both wheels and inspected everything?
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
Ball joints maybe (inspect before just replacing)...
Or if you have coilovers... they might be loose
rb20det_pwr
Car: skyline hcr32
rbsileighty wrote:Ball joints maybe (inspect before just replacing)...
I nominate loose coilovers, (if you have them), cus my brand new ones did the exact same thing before.
hapaboi39
Ball joints huh?Okay.Honestly im not even sure what a healthy front suspensions is supposed to look like.I will take pics and post em here.
Thanks for the feedback guys!
crzycav86
Car: 93 Nissan 240SX KAT
If it only happens at low speeds, perhaps your tie rod ball joint is the culprit.
You may need to have the ball joint regreased or, ideally, replace the tie rod end.
When you check the tie rod ball joint, it should slide side to side with ease.
hapaboi39
Thanks man.
Dude crzycav86 ur front end looks a lot like my front end.Almost exactly except your rims n tires R much better than what i have.
BadMojo
Car: 2007 Mazdaspeed 3
crzycav86 wrote:If it only happens at low speeds, perhaps your tie rod ball joint is the culprit.
Tie rod ends on my car are crapping out, and I have a low speed clunk on occasion. Got some Tein inner rods and tie rod ends, so all I've got to do is get off my *** and install them.
Anyway, I'd definitely check out the tie rods. Also, if the rubber boots are damaged definitely replace them. You want to keep the dirt, road grim, dead animal bits out of there.
hapaboi39
were the Tein inner rods and tie rod ends expensive?
KA24Power
Car: 1990 240sx
I had a similar problem on my '90 hatch. Turned out to be the sway bar end link. A little washer broke, and was letting it move around freely.
i'd check that, its pretty easy to look for too: turn your front wheels to the left or right all the way, and inspect the suspension. then compare it to the other side, and just look for anything that is different
ser2102
Car: 91 dead. 90 getting did
i have that clunking sound too, its when im at veryyy low speeds. mostly i hear it at drive thru windows haha. but yeah i cant figure out what it is either. sounds like its coming from the front. and i have coilovers and tension rods.
hapaboi39
I found tha problem. Its a bad strut. IS this an easy job?I was told i need a spring compressor.Sounds difficult.Anyone done struts b4?
wzntha
skydragoness
Car: 03' 350z Touring 6spd
92' 240sx 60k survivor :)
Thinks to check:
--Inner and outer tie rod ends--T/C rods--shocks--swaybar endlinks (like someone mentioned already)--ball joints either in the lca's or the tie rods
Also, don't forget the upper strut mounts. They should be replaced along w/ new shocks (all the way around) on a vehicle this old. There is a bearing inside that can lose its grease and if its gets dirt inside will start to bind and make clunking or popping noises at low speeds (like pulling out of a driveway perhaps). Check all bolts on all components. I had a knocking sound when i touched my brake pedal on my first S13 and it turned out to be a loose bolt on a LCA (don't know how it happened it just did! Potholes can do that sometimes).
wzntha
Broadfield
Car: 1992 240sx
I have the same issue, but have not had a chance to inspect/fix it. I will also let you know what I find.
Toby
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
I had the same symptoms in my s13 this past summer. Turned out that I had a blown wheel bearing. I mean BAD. You could move the hub up and down. Now I have nice new five lug hubs with buttery wheel bearings. Gotta love an excuse to upgrade!
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
hapaboi39 wrote:Whats up fellas!
Thanks
Check out the S13 Front Top Bearing Mount write-up about half way down this page. http://www.pdm-racing.com/products/suspension.html
positron1
You can get a set of outer and inner on ebay for $144.
positron1
Dude let us know how you like those when you get 'em on because I'm looking to buy a set.
naed240sx
Car: .....
positronone wrote:Dude let us know how you like those when you get 'em on because I'm looking to buy a set.
Tein tie rods and ends are pretty much exactly the same as stock. Buying them is a pointless waste of money, because they will not perform any differently than stock. Buy SPL or stay oem.
positron1
Thanks! That's the type of info I'm looking for.
oki_bum
Car: SR Powered 1990 240SX
Tein tie rods are definitly more beefier than the stock ones....they are not the same as oem. Performance-wise? Not sure, but they do advertise increase steering angle like all the other aftermarket tierods. The SPL ones do look pretty damm good though.
positron1
Any word on the quality of TC Sportline tie-rods or any of their products?
naed240sx
Car: .....
oki_bum wrote:Tein tie rods are definitly more beefier than the stock ones....they are not the same as oem. Performance-wise? Not sure, but they do advertise increase steering angle like all the other aftermarket tierods. The SPL ones do look pretty damm good though.
Yes they are thicker, but it doesn't matter, because they perform just like oem ones with the exception of the steering rack spacer (That provides extra steering angle for drifting that only like 1% of the people here could actually use). Autozone tie rods are lifetime warrantied not to bend/break, so that negates the purpose of buying tein rods for the thickness.
glitched
Car: 1992 240sx se
my paranoia is showing through today, Even though I dont have much experience/knowledge with suspesion, I have noticed that almost anytime a thread comes up, naed is bashing another product and says get SPL.... not saying spl isnt good, but its a trend I have noticed with posts...
hapaboi39
positronone wrote:Check out the S13 Front Top Bearing Mount write-up about half way down this page. http://www.pdm-racing.com/products/suspension.html
Jimminy christmas!!!!!Ur tha man!!!!
Thanks for that article, its very insightful and it describes my problem almost to a T.Too bad i already bought new kyb struts all tha way around. I had the problem diagnosed as a strut but it looks to be a front end bearing.Oh well another reason to buy stuff for tha 240
naed240sx
Car: .....
glitched wrote: Even though I dont have much experience/knowledge with suspesion, I have noticed that almost anytime a thread comes up, naed is bashing another product and says get SPL.... not saying spl isnt good, but its a trend I have noticed with posts...
Whats your point?
The suspension links that SPL sells are the very BEST in the market. Anybody who knows their stuff will agree. I bash Tein's cheap coilovers, tie rods, etc because they suck. I'm just giving facts.
Trust me, I have no connection with spl at all, other than the fact that I buy their products. I have also met the owner in person, and he is a badass guy who stands behind everything he sells.
positron1
Don Nimi is the MAN!!!
hapaboi39
Okay im tha guy who started this thread.After many many hours/cusswords later I fixed the "clunkity clunk" sound...It was a bent strut rod. My buddy and I replaced the struts w/new kyb's and i also installed the S-tech springs. SOOOOO HAPPY!!!
Yay for me...
Anyways no more clunky clunky...
I jus hope my struts wont blow out quickly.I got gr2's and i just recently heard that they have a tendency to blow out kinda fast w/lowering springs.
