Frankie1Eighty wrote:I'm having some big problems. My new s13 front end coversion doesn't sit right, i dunno why.
Problems:1.) the Hood has to closed EXTRA hard for it to even close.2.) The Hood doesn't align properly with the Fenders, sits lower then the fenders for some odd reason.3.) Where the Blinkers, and Headlights meet. They aren't flush. The Headlights stick out a lot more.
Does anyone know why this could be happening, am i supposed to tweak the body parts before putting them on my car. By the way, i have a 89 hatch.
Any Solutions???
Thanks
1. Your hood is similar to mine. I have to lift mine about 10 inches and slam it down, I believe its just a spring issue, but not sure.
2. You need to get some new rubber under pieces, the ones on the corners of your car/engine bay, your old ones may be worn out. Get some new ones and adjust them higher, and it will align up perfect.
3. I havent seen many cars with perfect alignment on these, mine fit considerably well although there is a little gap (larger than usual) under the headlights and corners.
