s13 clutch pedal ?'s
ToplessVert
Car: 1993 Nissan 240SX Vert
So here is my problem. I have a Vert, automatic of course. Found and engine and 5 speed trans, i have everything but the clutch pedal. All the 240sx's in the junkyards around me have been picked clean. Are there any alternatives such as a maxima/altma/sentra pedal that will work?
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
I have a pulsar nx clutch pedal and modified 240sx clutch master. It was a major pita and took some fabbing of the fire wall. If I had to do it again I wouldnt. I would just wait till I found a pedal assembly. Have you tried the classifieds here?
ToplessVert
not yet but there is a few sentras and maximas in the junkyeards as well a s a 300zx
compactfean
daily
If any of those might work id say the closest thing would be the 300zx.
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
hit the classified section, someone is bound to have a clutch pedal.
bartyb
Car: 98 Nissan 240sx SE, 95 SE, 91 s13, 89 s13, 03 Sentra SE-R
SR86
Car: Nissan
Honestly, you can use whatever clutch pedal you feel like using. Since they're all mechanical units, you can take one off a Ford if you really needed to. The only extra work you would have to do when using a clutch pedal and/or master cylinder assembly is make holes in the firewall for it, and find the proper fitting for the clutch fluid line to fit into the master cylinder.
Using an S13 one will obviously make the job easier since there will be notches in the firewall acting as template, telling you were to drill the holes and the hard clutch line will match up to it perfectly (if you did not purchase the stainless steel braided).
compactfean
daily
Yeah you can but take it from someone who actually used a pedal a**. From another car. Its not worth the extra labor. There is hardly any room to work in there unless the dash is pulled.
biggie
Best to remember in mounting the pedal that the S13 mounting points are already there on the firewall and all you have to do is drill the 2 bolt holes and the center hole for cylinder. When using a different clutch pedal all that gets screwed up, not worth it.
compactfean
daily
And don't forget the one bolt that's nearly to the top of the dash that makes sure your fire wall doesn't bend......that'd the hardest bolt. All because I want patient enough.
