bcar240 »
https://forums.nicoclub.com/bcar240-u13477.html
Wed Oct 28, 2009 5:43 pm
Update/solution? So I just popped the spring out and the problem is gone. The clutch is a bit heavier now, maybe 30% heavier. That's not a big deal, mine was very light anyway. The other difference is, as far as I can tell, the spring was progressive and calibrated to become stiffer around the clutch engagement zone for better control. When the spring is removed, there is less pedal feel, just a consistently heavier throw. I think I will remove the damper and see what that does.
I believe what actually happened that center section of the assist spring popped out of its notch in the clutch pedal and was instead riding on the side of the pedal outside the notch. But I'm not disappointed in the new feel, and barring any problems will probably leave it out (looks like it would be tricky to reinstall anyway.)
