180fan »
https://forums.nicoclub.com/180fan-u3602.html
Thu Dec 07, 2006 11:04 pm
s13 cross member yes.
The pedal stuff. Ok so here's the difference between the brackets. On the s13's if you look at anyone doing their manual transmission conversion, take a look at the firewall on the s13's. There's what looks like a C shaped metal column coming from it. That is where the bracket's studs go through. On the s14's, that column is integrated into the bracket. You can probably go to a hardware store and get a bunch of brass spacers that can do the job. How long you'll need, I'm not too sure of. You can try getting a spacer a couple inches long like 3 or 4 and cut it to fit it, but that can also lead to premature pedal failure too. So my suggestion is order a bracket from somewhere like Midway Parts and be happy with the bracket. Source the actual pedal from a yard, but keep the other parts to it, like the return spring, the other little plastic parts and the nuts and bolts. Sometimes a used bracket isn't the way to go. I took the one from my old SR clip and that one snapped on me while I was on the freeway going off an off ramp. Not exactly the most fun.
