s13 cluster illumination no more
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
Hey guys i searched last night and had trouble finding the illumination wire for the s13 gage cluster. it seems theres multiple possibilities, so if anyone knows how to read their fsm better than I be my guest and post.
Not sure if it was me fking with the wiring last night fixing my wiper intermittent speed and bringing power back to that circuit that screwed up my cluster,
but now the cluster won't light up and I'm havin trouble.
It was dying before a few random times the cluster would not light up, but this time it's perma-dead lol.
s13_chris
Car: 90 240sx Hatch
If it worked before you did the work, go back and check it all.
charat
Car: 1992 Nissan 240sx SE, 2008 Honda civic EX
for me, it didnt have a ground... check your circuits and grounds.
Didderson
'74 Datsun Z
well I did undo the wiper power wire fix and still no luck.
Also, the 2 grounds i can identify have low to no resistance.
I stole power from the cruise control wiring illumination to get headlights on power, and put it on cluster pin 24, no luck.
put it on cluster pin 20 (it gets power at pin 11 still)
no luck.
tried powering them both simultaneously too and nothing.
Rarrghhh fukk
Didderson
'74 Datsun Z
if theres a ground on the plug behind the gas gage let me knoww
edit: ok nvmd i found that one, ground is fine on this one too.
I'm wondering if my dimmer switch is dead..
Didderson
'74 Datsun Z
OK, it was the TCU i got at the junkyard. it was bad. my old was was still kinda bad but hahaha... o well.
Didderson
'74 Datsun Z
my old one is good i guess, just the intermittent wiper signal wire has low voltage. its like half burt out
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I think the "Ill" is a low reference, I just threw out the printed version of the prints from when I did mine.
Didderson
'74 Datsun Z
Low reference? I'm not sure what it meant on the back either but that green wire to pin 24 and returning my original TCU was the key.
Thanks for chimin' in.
On a side note, if I get low voltage on a wire (the green one pin 24) could i just splice into it and run a jumper power of 12v? I don't think this is a good idea because I was thinking it would backtrack and ground out the new power yea?
Either that or it was low because the dimmer does that. Idk
