driftdevil.com wrote:thats kinda odd.. because polyester takes dyes better than any other type of material.. (this coming from a clothing manufactuer, should be the same all around)
the brand of dye i bought is called "Rit Liquid Dye". the directions in the back specifically say:
Use one bottle for two pounds dye fabric. add one cup salt to dyebath for cotton, rayon, ramie, linen, or blends. Polyester or nylon blends dye lighter. Not recommended for 100% polyester, acrylic, or fabrics with special finishes, rubber backing, cold water wash, or labeled "dry clean only". if in doubt, test dye a swatch. NEVER POUR DYE ON FABRIC. Wear rubber gloves. RIT will stain plastic, fiberglass, or worn porcelain tub. use RIT color remover before dying to lighter or different color. wash dyed items separately in cool water. for dark or bright colors, double dye in quantity.
i absolutely have no idea on how to use this thing. do i just simply spray it on and wash in cold water when im done? and since im dying what are already GREY seats, can i just spray the dye on it completely without having to use color remover?
