1sikvert »
https://forums.nicoclub.com/1sikvert-u75568.html
Tue Oct 02, 2007 8:24 pm
Well I recently purchased some clear corner lenses off of "FleaBay" to replace my amber ones and I searched on here to see how to replace them and I found a few threads but none with pictures for our S13s. So that's when I decided to take some step by step pics of my partake of the install, so here it goes:
Lenses fresh out of the box
Side view of the lens
The driver's side lens easily comes out with a little elbow grease pushing the lens towards the back of the car
Here is the lens popped out, next you must remove the bulb from the lens and disconnect the connector
Then slide the female side connector off of the metal bracket if you can. Mine wouldn't budge so I had to break mine and then cut the remainder off. Then slide the female connector back onto the new bracket of the clear lens
Then you can use an adhesive of your choice and line the edge of the new foam and slide the lens back into place and there's the driver's side
Now onto the passenger side. The lens slides right out just like driver's side by pushing it out towards the rear of the car.
There is no sliding bracket on this one so you only need to remove the bulb. No harness disconnecting here.
The new passenger side lens holes are different from the stock one in this case so some slight "modifications" are required. You can either notch the new lens in order to fit the bulb or simply round it out just enough to wiggle the bulb in. The second option is what I chose to do since I was feeling kinda lazy. You can use a drill with a boring bit or a pyramid type bit like I used.
Finished product after modifying the new lens
Now just carefully wiggle the bulb into the new lens
Then just like the driver's side lens, take your adhesive of choice and line the foam with it and then slide the lens back into place. If your passenger side lens comes with the extra bracket like the driver's side did be sure to remove it before sliding the the lens into place. It should be easily removed with a phillips head screw driver. If you just don't care, there should be enough room behind the fender to just leave it on. I decided to remove it since my stock lens didn't have the bracket on it and since I had to break my other one on the stock driver's side lens so I replaced the broken one to make it as good as new.
Finished product
Before
After
I hope this helps some of you out a little more since I know pictures are worth a thousand words and I personally like to see pictures of an install like this myself. Just let me know if you have any questions, I would be glad to help out!
Modified by 1sikvert at 12:52 PM 10/4/2007
