hahahahah, good like putting a big block in an s13's engine bay2LO4URHO wrote:Tell 'em I'll take it!
That's why I recommended LT1, the OptiSpark setup is on the front of the engine so no bid distrbutor in rear. There's no doubt the LS1 is better in every way, it's just going to be harder to find in a junkyard and cost quite a bit more.eazye2000 wrote:Only thing I don't like about using an older small block chevy motor in a swap, is the distributor in the back. Especially if you're using HEI ignition.I would much rather have the newer LS aluminum block. Not to mention the ECU's can have stuff DELETED in them! Like the gas tank pressure sensor..(cap off) Rear O2 sensor. blah blah.Lots of other stuff, but I'm tired. bleh
To swap throttle body for carbed.... swap the intake manifold, and swap the fuel pump. By the way, EFI would not work. Unless you can wire up the chev computer to make it work right.2LO4URHO wrote:
I see, so you're saying go all carburated or all fuel injected, throttle body is the worst one?
dude, thats not a big deal. ive seen plenty of v-8's with single and twin turbo's. there not stupid fast until you get to that 88mm and up rangersagen wrote:i drive a 89 as a daily and just bought a 90 for my beast. I am planning on dropping a 400 chev small block into the 90. high compression pistons, the whole 9 yards you know. then i came across gold. I went to a swap meet, and picked myself up a frickin TURBO for a chev 350, never heard of em except for the super muscle cars, well long story short, i think this car is going to beat anything that comes up on the red light. So this would be called what in the terms of nissan? C400KT? (Chev 400 Carbed Turbo'ed) lol.
Couldnt you just use the stock fuel pump right off the motor. on the older motors the fuel pump was run just like the power steering pump, I would think that would work the same way, I dont see why you would even need to brother about the inline pump, if it had the clearence to fit, correct me if im wrong pleasethe_momo wrote:Just a little heads up, I did a sbc 350 swap about three years ago in one of my s13 coupes, a few things youll need to do
1. you need to chance the fuel pump to a low pressure if you are using a carb, i used a dip tube in the tank and an inline pump, worked great.
you could definitely use the stock pump, but regulating them down causes a lot of extra heat and the stock pump just doesnt take it well, thats all. I used and aeromotive fpr and the stock pump, and it crapped out because of overheating (yes i had fuel in it the whole time it was never run dry)hotrod240sx wrote:You could just use the factory 240 pump and get a regulator with a return outlet like 1 that mad makes last time I bought 1 for a project it was about $85-90 I think. Put a gauge there to regulate it down and done there. The biggest problem I have found is doing the exhaust noone to my knowledge makes headers for a old school 350 or WBC into a 240. Best bet possibly would be to try and modify some shorties.
It does matter. Start a new thread.rsagen wrote:doesnt matter if its an old thread, does anyone know of a thread that has a list of things you have to do, to swap in a 350?
Heres how to swap in a 350:
Remove old motorMake custom motor mountsinstall 350
You'll have to work out the details in between as you go.
Following proper etiquette will take you far, both in online forums and life in general. Good luck with both.rsagen wrote:Im sure it doesnt matter. Mods get pissed when you start a new thread for every little thing.
Unless you got something constructive to say go piss up a rope
Overall, pretty good. You?comatoseculture wrote:Hey BRO! How's life?
Not sure what that means. I always appreciate well-wishers though!comatoseculture wrote:btw-good luck being a rebel/power control freak in both online forums and life itself. I hope it works out well for you.
Hmmm. I can tell I'm just going to disappoint here.comatoseculture wrote:LOL- I can tell you're the type that MUST uphold your internet honor...so I'm glad I made a new friend, can't wait to see how clever/well prepared/attempting to be more mature your response is.
If you have a question, chances are its been answered on some level or other. If it hasn't been answered, then you should by all means ask. A 2 year old build thread isn't the right place. If nothing else, It makes it harder for others to find later. Which feeds back into the whole search/find/new/old issue. I, personally, have never been shot down for starting a new thread. No matter how stupid the question.comatoseculture wrote:edit: you know, I don't really know why I'm so pissed off, but I am. It's literally useless, I'm practically just as bad for responding, but seriously, this forum has a rash of "don't start a new thread/SEARCH you idiot" and then the counter "start a new thread, this one is old". Well which one is it? want us to search and research the old info, or ask the question?
I am totally a mod. I just forgot my logincomatoseculture wrote:And I know that I am not a mod, but does crazyirish realize that he isn't either? Well, you aren't. So don't tell anybody else what they should be doing on here. Right? Or Wrong? Can I get a witness?
