s13 catback size difference?!
x Too Fly x
Car: 1991 240sx s13 hatch
would a 3in catback fit on my stock piping?!?! i bought one and im tryin to see if i need to modify it any to make it fit? help me!!! thanx.
yea ima noob. haha
Ilvemynissan
Car: 240sx s13
Welcome to NICO!
And i'm thinkin it should fit. Try slappin the shizz on
x Too Fly x
hah ight thanx
D-UNIT
Car: a 91' S13 (15.014 @ 94.56mph NA) KA-T
I bought a Megan 3in cat back w/ a 3in test pipe for an SR and it bolted right up to the stock exhaust manifold.
x Too Fly x
ok thanx you all are giving me good advise. my catback comes in tha mial tuesday and ill put it on.
thanx again.
x Too Fly x
ooh does that mean i have to get a test pipe or sumthin.
D-UNIT
I couldn't say. I never had a cat so Idk. It should work though , because the manifold bolts and the cat out bolts are orientated the same way. So test pipe - no test pipe probaly doesn't matter. The reason I have a Tp is because I got as a combo deal for $400. I wouldn't have bought Megan otherwise , but I like it now.
x Too Fly x
ha yea i juss have a muffler now and it sounds really good.
but i decided to get an actual catback. but yea wen i get it i will throw it on.
Ilvemynissan
Car: 240sx s13
Be sure to post some pics after you got it on.
x Too Fly x
ok i wont and it didnt come in tha ups today so tommorow for sure!!
x Too Fly x
ok well tha bolts are too rusted to actually bolt off. so we dcided to grind em off. well we did and now we cant get them out of tha hole. hahah i dunt kno its kinda hard to explain!!!
Ilvemynissan
Car: 240sx s13
Drill it out? I don't really know man.
x Too Fly x
ha yea thas wat i was thinkin but i wasnt sure and i didnt have time bcuz it started storming. i just got soo frustrated with it i gave up for tha day.
but if i drill it out ill put pics up for sure.
x Too Fly x
well herer are the pics of tha catback itself!
Gabes13
Car: rb20det s13
nice. did you say it was a megan?
x Too Fly x
ha thanx and no i have megan springs.but it looks god and ill put pics on my other thread.tha one bout my 240.
nismoracingsx
Car: 1993 White 240sx Coupe
same happened to me with my catback, i grinded the bolts off but ended up taking the car to a shop to have the holes drilled out, took them like 25 minutes though because the type of metal kept overheating the bit or some ish
x Too Fly x
ha yea they didnt even drill my holes big! it was like a medium size.
nismoracingsx
the large bolts that came with my catback wouldn't fit the converter's holes, so i just picked up a slightly smaller bolt @ advance and popped em in.
x Too Fly x
yea but now mine is like messin up. i have a leak and ima take it to a muffler shop!!
80watthamster
Car: 1993 240SX Fastback
If things line up pretty close, you can try putting some muffler and tailpipe sealant on your gaskets (you did use gaskets, right?), or even alone. Use Permatex if you use anything.
x Too Fly x
ha well see here is wat happened wen i was bolting it up(i did use a gasket) but one bolt wouldnt fit and im lazy so i didnt want to drill tha hole bigger so i used a smaller bolt instead tha one they gave me! so now i have a lil leak! i think it wont bother too much but it should sound better if i get it fixed. am i right?
Ilvemynissan
Car: 240sx s13
If that's the problem then yah it will sound better when fixed. And just drill the hole it's not hard.
x Too Fly x
ha but it takes forever!! haha
