s13 car alarm? wth?
SHIFTrl240
Car: 1990 SR20 Sil-80
2009 Yamaha RoadStar Warrior
2017 Alfa Romeo Giulia Ti AWD
yeah so im sitting here and just a second ago i hear a car beeping like a car alarm so i look out my window and my car, which is parked on the other side of the street, is flashing its emergency blinkers and beeping as if the car alarm was going off
wth? there was noone that i could see around the car but i didnt even know that the car did that. ive had it for a year and thats the first time it has ever done that....
Yorb
Car: 1992 Nissan 240SX SE Fastback
maybe the previous owner put a car alarm in it. =P i dont think any of them came with alarms to my knowledge. but i installed an alarm in my 240, and if i so desired i could have made it entirely invisible. easy to tap it into the horn if you dont have a siren. look around for an alarm brain, usually stuffed up under the drivers dash somewhere or under drivers seat.
kinda weird that it wouldnt have set itself off for a whole year though and then suddenly do it for no reason.
SHIFTrl240
yeah its wierd, i just went out there and pushed it and shook it, pulled the locked handles and everything and it didnt go off
i have no clue whats going on
Yorb
=o mb this thread will be useful
http://www.nissaninfiniticlub....57624
those are s14s though. =/ i dunno.
SHIFTrl240
yeah i know some s14s have stock car alarms, mine shouldnt but yet it just went off, and i don't know what triggered it, and i cant get it to go off again
Yorb
have you tried SERIOUSLY shaking the car? because i know if a sensor did actually set it off, its probably a shock sensor, and its probably configured very weakly so that it takes a lot to set it off. if a big truck went by nearby or a big bass system, that coulda done it. maybe the sensor was attached loosely for the past year but it got wedged somewhere and picked up the vibrations this time around or something.
i dont know. but as far as i know there's only 4 kinds of sensors: electrical (door opening), shock, motion, and glass-break (microphone). unless glass broke somewhere nearby it wasnt that. you would have noticed the motion sensor sometime in the past year. shock... well, coulda been, i mentioned that above.
otherwise your car is possessed ;D
SHIFTrl240
i'll give it a try tomorrow, but if stock s13's didnt come with alarms... i must have just been dreaming or something. i havent seen anything that looks like a car alarm from all the work ive done on it... but i dunno i was trying to post on here and see if anyone else had ghost stories such as this
el5y
Car: 93 240sx
some do have alarms, my brother's 1990 hatch does, the switch for it is located on the right side of the steeringwheel between the rear defrost button and the steering column, atleast thats where his is, its not exactly the most useful alarm, because as you have seen it goes off randomly, and once you get in to the car all you have to do is switch it off so it'll stop. I don't have anywhere to host the picture of it right now but I will eventually. it has 3 settings, On, Off, and Impact Off which obviously have their uses.
EricEDIT: I'm hosting them at my school account, will only be up for a few weeks at best
http://www.people.virginia.edu/~el5y/alarm1.jpg
http://www.people.virginia.edu/~el5y/alarm2.jpg
SHIFTrl240
mine does not have a switch like that there, it has just a flat plastic cover panel... wierd .... mystery still unsolved
if there was a car alarm installed, and the switch or whatever is hidden, is there a place in the wiring i can check to see if it has been tapped into for the alarm?
Yorb
that's interesting. mine has a flat piece of plastic there too, and on the right side is the rear wiper/washer controls (instead of that little sticker on yours...can't read what it says).
maybe it was a dealer special thing, and some dealers just didnt put the little switch there? i still advocate searching up under the drivers dash, there's gotta be SOMETHING
el5y
Car: 93 240sx
its a warning light for if the Over Drive is off.....(my bro's car is an auto..........:()
I really dunno what it could be then
Eric
megaman3
I just bought my 91 240sx LE a few days ago. It has a stock alarm, came with the original manual and everything. It says the alram is configured into the ignition and stuff. Yes the switch is on the right hand side of the steering wheel next to the rear windshield wiper button and its a manual.
silkk
Car: 94 B13
89 S13
07 S2000
its a ghost!!!
*boo*
wickedpelf
Car: 1991 240sx with super hicas
any way of retro fitting an s14 alarm to an s13? or would it be easier to just get an aftermarket alarm? oh and BTW some where on this forum there is the 240sx service manual...try to find that im sure itll have ur awnser to what ever question u have...
Yorb
doubt it, i have an FSM and it mentions absolutely nothing about alarms or even speakers/audio (besides general placement location of the speakers)
Silvia2b
Car: 95 240sx se / 07 G35s cpe / 2009 G37s sedan (rear-ended R.I.P.) / 19 Q50 rs400AWD
The S14 FSM has detailed explanations for testing and t-shooting the factory security system. No siren though just horn honking. I've never seen the factory S13 alarm that came in the LE vehicles, but it sounds like the same add on that they put into the Pathfinders at the dealership.
I agree, get on your knees with the drivers door open, use a drop light and take a peek under the dash, most installs are not so clever as to hide all of the components. Look for wires not run in split loom or wrapped in old electrical tape, they are usually a good indicator of the presence aftermarket system. You can also look under the hood for the siren, or near the battery's positive terminal for fuses that are connected there.
black s13
S13's were available with a dealership optional Clifford alarm. one of my parts cars had it, i asked around, and thats what i came up with.
Silvia2b
What? Clifford has almost always been sold exculsively as and aftermarket product, even now! I wonder if some auto dealer just had a bunch of cars done at stereo shop to sell them with a security for a little extra profit.
