S13 - Can I use 12mm X 1.5 fine lug nuts?
Aiki-Drift
Car: S13 coupe
The new wheels I'm purchasing call for 45 degree taper racing lug nuts. The lug nuts that they sell come in 12mm X 1.5 fine size. I don't see 12mm X 1.25. Can I use this size or will it not work. Where can I get the lug nuts that will. They HAVE to be 45 DEGREE TAPER or it won't work. Thanks guys.
Ubernoober
What do you think? When was the last time you cross-threaded something and it worked?I suggest either searching the many many makers of lug nuts for a set that works, or replacing your studs with 12 x 1.5 .
onosqv
Car: '92 240sx Vert
Aiki-Drift wrote:The new wheels I'm purchasing call for 45 degree taper racing lug nuts. The lug nuts that they sell come in 12mm X 1.5 fine size. I don't see 12mm X 1.25. Can I use this size or will it not work. Where can I get the lug nuts that will. They HAVE to be 45 DEGREE TAPER or it won't work. Thanks guys.
Like ubernoober said, save yourself the trouble and get 1.25, nissan threading. Won't cost you much extra.
Then go sell your 1.5 to the toyota or honda guys.
